[SOLD] New! 1.46 valve springs
rumblefish360
I have escaped the EVIL Empire State!
Florida
I have for sale 16 of each of the following;
Hyd. Cam Valve springs at 1.46 diameter (specs below.)
Steel Retainers
1 grove locks
This, I will sell as a package only. They came off of my wife’s ProMaxx cylinder heads in flavor for what I need to have on them. These are (again!) New, never used with the following specs;
Hydraulic Flat Tappet .575 max lift
Closed ………………….. 115 lbs. @ 1.800”
Open ……………………. 310 lbs. @ 1.225”
I don’t know who’s springs these are, they could be?
Comp Cams springs or Crane springs?
??? Edelbrock’s springs ????
I don’t know so I don’t know the spring rate.
$85 shipped in USA
Pay pal OK.
Freshen up your old cylinder heads!
Make an offer.
Doing a mild build 340. Cam is a Comp Cam XE268. Springs you have be to much?
ProMaxx spec’d the springs for a Hyd. Flat Tappet cam like what you have. There very very close to other similar low pressure springs from Comp and Crane. But I don’t know who’s springs they are. By way of looking at the information I gleamed from the ProMaxx site on the springs, you can use those numbers in a search at Summit racing to help narrow down the fields until you get to a spring or springs that closely match to what Comp Cams recommended spring specs are.
