OldmanRick - probably going into a 70 Barracuda 4 speed, 355's to 391's
Wis - did the entire setup for less than 15 - budget build (heads and all)
Cracked - agree, what target range I was looking at too
Rumble - No, heads are not ported, budget. When they installed the 2.02 they cut a lot of meat out though, and had the springs matched to the cam.
Estimating compression to be a about 11 1/2, everything is decked, 191 pistons, open heads, thick Felpro gasket.
Now have to clay valve to piston - is this an issue in small blocks with cams this size?
