New oil pump. Prime with accumulator?
71_dart_swinger
central valley cali
So. I am about to put a new oil pump on my 440 in 71 dart. After putting it on. Can I use my accumulator to keep the oil pressure up and just start it. Then if the oil drops to much. Turn it off. Reset the accumulator with air. Repeat? Thanks. I guess mainly curiosity? I work at autozone and will just rent the drive for drill.
Pack the pump with heavy lube or grease as suggested. Crank it on the starter or get/ make a priming shaft. REMOVE THE FILTER
Why!!!???
Because the filter is the first thing the pump outputs into, and by removing it, you remove ALL head pressure. The pump will easily prime with no head to work against. Yes, it will make a little mess. Crank the engine by jumpering the starter relay so you can see it, and provide towels, drain pan, etc. That pump should prime in just about 1 second of cranking time with no filter
Then fill your filter as much as you can, tip it side to side and it will take more. Spin it on, recrank, look for oil pressure on a gauge.
