I rebuilt my 5.9 magnum with a Hughes cam and EQ heads. They never said anything about return springs. I'll order some up and install them next winter.
I heard that you can just coil them through the spark plug hole without popping the head.
The new unobtanium springs are the way to go !Will you get more torque with a heavier spring?
I swapped in HEMI springs in my 318.....kicks ***!
Jeff
Awesome site!!!!!Order them here
Piston Return Spring - $54.99 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
I notice you have to specify if you have a boxer engine. Must be lower tension because they don’t have to push up.
Additional swirling action due to the spring rotation and can be installed in the left or right position.
Yeah, 'cause there's no chance you might slip a tooth on the crank pulley while you're dickin around pulling the head off or anything, right?I thought the three different colored marks on the timing belt was a nice touch.
No, that's why spark plugs gaps are so important, they help preload the spring. I've always been told to remove .005" from plug gaps in the winter just like you remove 5 wts. from your oil for cold weather.How do you back them off in the winter? Do you have to remove the head?
WOW! Man, remind me not to buy ANYTHING you are selling!No, that's why spark plugs gaps are so important, they help preload the spring. I've always been told to remove .005" from plug gaps in the winter just like you remove 5 wts. from your oil for cold weather.
nope, that won't work. You need adjustable head gaskets to change spring preload seasonally.No, that's why spark plugs gaps are so important, they help preload the spring. I've always been told to remove .005" from plug gaps in the winter just like you remove 5 wts. from your oil for cold weather.
