hey guys i was given an Offenhauser Single Quad High-Rise Intake and im doing a mild build on a 360 i was wondering how this will perform? i do plan on getting it port matched and all that facny stuff
Ought to work just as well as any other dual plane high rise, short of an air-gap.....and it's paid for!
Unless it's a Dual Port with the ports split in two horizontally, or a single 4 tunnel ram. Nice Valiant by the way.
Alan
Yes, it should perform fine. I would put a open spacer on top if I had room so both side of the engine can feed off the carb at once. You might want to try this if performance isn't what you think it should be. You'll also need to richen up the carb a bit since it's now on full time work duty feeding the whole engine instead of just one side.
