There are some wicked runing small blocks out there. But my 73 dart swinger that weighed 3520 with me in it, ran 10.62 at 126 in the 1/4 on 93 pump gas. I had a 0.030 over 440 with about 10.9 compression. Installing 2 750 Holley DP and letting my friend drive it. He weighs about 100 pounds lighter than me at the time. The car ran a bunch of 10.49 in the 1/4. So I'm saying this you can run pretty fast on pump gas now daysSo given a 450 - 500 hp engine, would a big block be more economical to build than a 360 at the same hp? Would the BB run better on pump gas? Apologies to the OP if I this is straying too far off your question .
Out of curiosity, what gears and tires were on it at the time ?There are some wicked runing small blocks out there. But my 73 dart swinger that weighed 3520 with me in it, ran 10.62 at 126 in the 1/4 on 93 pump gas. I had a 0.030 over 440 with about 10.9 compression. Installing 2 750 Holley DP and letting my friend drive it. He weighs about 100 pounds lighter than me at the time. The car ran a bunch of 10.49 in the 1/4. So I'm saying this you can run pretty fast on pump gas now days
I had 4.10 in it but blew them up on the 4th pass. So I installed a set of 4:30 I had laying around. The tires were M/T ET Street Drag Radials in 275/60/15. I think the car would of been faster with the 4.10 but I never got around to trying a set again. Also my dart had the wrong stall at the time. I had a 9.5 inch converter that only stalled around 4200, the car should of had a 5200 stall converter. Which latter on I added, but never got to race the car before I sold it. Also my car was 100 percent street ableOut of curiosity, what gears and tires were on it at the time ?
cool !I had 4.10 in it but blew them up on the 4th pass. So I installed a set of 4:30 I had laying around. The tires were M/T ET Street Drag Radials in 275/60/15. I think the car would of been faster with the 4.10 but I never got around to trying a set again. Also my dart had the wrong stall at the time. I had a 9.5 inch converter that only stalled around 4200, the car should of had a 5200 stall converter. Which latter on I added, but never got to race the car before I sold it. Also my car was 100 percent street able
It should have no problem firing the 383...it doesn't know how many cylinders or cubes the engine has. The trigger to fire comes from the distributor.I've got a 383 I want to throw in my Duster. It has factory electronic ignition for a slant six. Will that be able to function on a 383 or am I better off just using points for now?
I see you are running a motor plate. There is a Hemi Dart running in a local street car shootout we have in Richmond and I didn't want to bother him last night as he was dealing with chassis issues but he has motor plates also and it did not look like the K Member was notched for the oil pump and he had quite a bit of space. Why did you go with Motor Plates?I had a 440 in a 68 Dart. -- (1) I cut a hole, with a hole saw, in the inner fender. to gain easy access to the #7 spark plug. -- (2) Torsion bars run thru TTI headers. -- Neither was a big deal.
-- The motor was in another car, that I bought, and it was set-up that way. - It was a 440 stroker.-- Why did you go with Motor Plates? -- JW
The TTI headers I used the Torsion bars did not go through themI had a 440 in a 68 Dart. -- (1) I cut a hole, with a hole saw, in the inner fender. to gain easy access to the #7 spark plug. -- (2) Torsion bars run thru TTI headers. -- Neither was a big deal.
soooooo, what are you gonna do?What were the biggest things/problems you had to overcome to do the swap? I'm up in the air as to whether I want to do the swap (got a line on a 400) or go with a 360.
For right now I'm leaning towards a small block. A small block will let me get my Duster on the road cheaper and faster...but maybe a bit slower.soooooo, what are you gonna do?
another thought is to use an aftermarket K member that eliminates the torsion bars, like the one HemiDenny makes -- HemiDenny
If folks would step out of the 70's they would realize that there IS indeed a replacement for displacement...As I'm sure it's been said before, no replacement for displacement!
Turbos are great but the cost and effort of setting them up is sometimes astonishing.If folks would step out of the 70's they would realize that there IS indeed a replacement for displacement...
