I also just noticed on rock auto they have eccentric bolts and washers and some say plus or minus 2.25 degrees. Is this just a stock replacement or do they add more adjustment then factory eccentric? If it's a stock replacement why do I have a full degree less available to play with.
Summit lists the same part # as plus or minus 1.13 degrees, for a total of 2.25 degrees. https://www.summitracing.com/parts/mog-k8243a/overview/year/1971/make/dodge/model/dart
Meanwhile, QA1 lists theirs as +/- 2.5 degrees. https://www.summitracing.com/parts/qa1-52361/overview/
Again, the total adjustment is limited by the length of the slot in the UCA mount, the bolt and eccentric just allows the adjustment by turning the bolt. The offset of the bolt in the eccentric would change the amount of adjustment, but you can't add more adjustment than what the slot in the mount allows. The stock bolts don't leave much room in the eccentrics either, you couldn't offset the bolt much if any more. I think this is all just misinterpretation of the specs of the bolts, the QA1 bolts don't look any different than the stock ones and the eccentric washer and bolt have to be the same size.
