terry
Hi folks
Years ago I sent a pair of sbp ralley rims to Stockton wheel to be converted to a 15 inch by 8 inch wide rim bs is about 4 3/8. I have now noticed that the welds on the back side of the rim is in 4 places every 90 degrees about 5 inches long then there is a spot about the same length with no weld. now this is right above the 10 half circles of the inner rim to the outer lip section. should I be concerned if there is not a complete welded circle? on a couple of the non welded sections I can see light between the inner and outer rim.
