JeffreyLee
1965 Barracuda
I am just starting to tear down my front end and replace my bushings with a kit on its way from PST (rubber). Taking brake parts off was easy, it looks like the suspension parts are going to require some hard core wrenching and bigger tools. if there is a step by step guide to disassembly and rebuilding the front end on this car, it would be great to reference. I have 10" drum brakes which I am just going to clean up. My first quandry is that I have new brake cylinders which I want to install and I can't seem to access the bolts on the back of the wheels to remove the cylinder. The brake fluid line is right next to the bolt on the back, which I removed, but there is still no room to get a wrench on the bolt. I expect that I will have the front end parts removed as part of my re-build, but i can't imagine that you would not be able to remove a brake cylinder by itself without a bunch of extra work. Am I missing something here?
Thanks Guys!
Thanks Guys!
