Rotting engine.
Discussion in 'Small Block Mopar Engine' started by mhuppertz, Apr 14, 2012.
Discuss Rotting engine. in the Small Block Mopar Engine area at forabodiesonly.com.
  1. mhuppertz
    mhuppertz Well-Known Member
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    So, I guess it isn't good for an engine to sit for 23 years. I ran it about 30 minutes that water started gushing out of the front of the intake. This is what I found....
    [​IMG]
  2. Divenut
    Divenut Well-Known Member
    2,161
    236
    Sep 22, 2011
    Naperville Illinois
    Local Time:
    12:53 PM
    That would do it! :shock: Damn!
  3. lugnut1962
    lugnut1962 Banned
    666
    1
    Mar 8, 2011
    Poulsbo
    Local Time:
    10:53 AM
    You will find more....but starting after 23 years? Don't think I could. Good motor. Not rotting, just needs a lil TLC.
  4. jimjimjimmy
    jimjimjimmy lobsterman FABO Gold Member
    3,090
    172
    Nov 2, 2010
    p. e. i.
    View My Photos
    Local Time:
    2:53 PM
    wow i never saw that before even on 20 year old chrysler marine engines in salt water
  5. needsaresto
    needsaresto Well-Known Member
    7,775
    120
    Nov 13, 2004
    Local Time:
    10:53 AM
    At least it's a cheap and easy fix.
  6. jaimus
    jaimus Old School ASE Gold
    2,435
    148
    Oct 12, 2010
    Hadlyme, CT, USA
    View My Photos
    Local Time:
    1:53 PM
    What else you find besides this and bent pushrods??? Any water/antifreeze in oil?? DO NOT tap your freez plugs too hard,...They will leak.
  7. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    Had to quit tearing it down. Too freaking cold outside!
    The water passages in the intake are full of calcium and possibly aluminum flakes.
    There is no water in the oil, it was good. There is no sludge at all in the engine. It's a mystery why it ran so well yesterday then all hell broke lose this morning...
  8. jaimus
    2,435
    148
    Oct 12, 2010
    Hadlyme, CT, USA
    View My Photos
    Local Time:
    1:53 PM
    Did you say it was too cold???You guys havin bad weather down there? Cause Its like 55 here at 10 pm...
  9. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    Yea, 34 degrees at 8:40pm and threatening to snow. High altitude (even this far south) is pretty unpredictable. I went to get my Dart two weeks ago the car had never seen snow. We brought it home and it snowed 8" on the poor car!
  10. jaimus
    2,435
    148
    Oct 12, 2010
    Hadlyme, CT, USA
    View My Photos
    Local Time:
    1:53 PM
    Oiy,...Keep us posted.
  11. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    20,211
    1183
    Aug 28, 2009
    Ontario
    Local Time:
    12:53 PM
    Wow, hard to believe a car thats never seen snow is decaying like that! I wouldnt run it anymore, I would do a complete teardown just to be on the safe side.
  12. jos51700
    jos51700 Well-Known Member
    2,746
    143
    May 24, 2009
    Bel-Ray
    Local Time:
    12:53 PM
    Lack of cooling system maintenance caused that aluminum part to react with the iron and coolant and create a giant battery.
    If this car has an aluminum water pump or timing cover (or any other aluminum motor parts in the cooling system), I'd seriously plan on removing them for a thorough inspection.
  13. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    This was less that two weeks ago!
    [​IMG]
  14. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    This is how she looked yesterday after I cleaned her up a bit.
    [​IMG]
  15. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    I am pretty sure that's exactly what happened, electrolysis. The water pump is cast iron. Pretty sure the engine is toast at this point after bending pushrods and stuff (see my other post).
  16. jaimus
    2,435
    148
    Oct 12, 2010
    Hadlyme, CT, USA
    View My Photos
    Local Time:
    1:53 PM
    Definitely looks salvagable,....is that an original black plate I see?
  17. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    Yea, the black plates are still on there along with the Van Nuys Dodge plate surrounds. I plan on leaving them on and sticking the New Mexico plate in the rear window.
  18. jos51700
    2,746
    143
    May 24, 2009
    Bel-Ray
    Local Time:
    12:53 PM
    That might be going a little far. Head work maybe, but not toast.
  19. mhuppertz
    134
    4
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    11:53 AM
    I mean toast for my situation. Since I don't want to run the 273 anyway it has crossed over the "false economy" threshold. I just need to find me a 360 now and start saving for a stroker kit with a scat forged crank....
