Does anyone know if a stock speedo cable on an early A will bolt up to a late model 904? And if it will not what does work?
Thanks,
Thanks,
Take the old parts off the tranny and screw them into the newer tranny. These parts are the housing the cable screws into and the gear behind it.
The newer 904 use's a different set up.
Has to be a 66 cable (maybe a 67 also, not sure about that.) the speedo end changed around 67 or 68. A 66 cable has the early speedo end, and the late trans end.66 and newer cable will work not jst a 66
I haven't heard of Brewers before.
