negative - that might have been Karl
Nope, not me...
you all gonna make me research back aint youNope, not me...
Hi Folks, I'm back on line.
It was a long steamy night and power didn't come back on until about 4:30 this morning. When the house finally cooled down around 6 am, I finally fell asleep for a few hours.
I just finished up some stuff for work and figured I'd check in here before catching up on what I missed in the thread since last night...
welcome backHi Folks, I'm back on line.
nicely done..who would have thought ....
had a customer with a late model ford car with a 5 speed.
Complaint is that it keeps popping out of 5th gear on the highway and no matter how hard you try to hold the shifter in 5th....it doesn't want it .
So I check the shifter linkage .....seems fine.....I check the motor mounts to make sure everything is aligned right, in case there is a linkage problem due to something out of alignment .....all checks out fine
so then I think maybe the clutch, pull the inspection plate and look in, definitely a used clutch but looks fine
finally I check the transmission fluid level and it's 3.5 quarts low (presumably from a axle seal leak)
fill it up with fluid and it runs totally fine now and is not popping out of gear anymore and is smoother shifting.
it's like a safety function??? trans knows there is a problem and tries to talk to you to tell you that SUM DING WONG !!!!!
It's coming back in a week for new axle seals
What year is the car? If it's the late model 5 speed with the Mazda tranny like my '96 F-150 had in it, being low on fluid causes 5th gear (overdrive) to pop out. It's because of how the hydraulics work in that manual tranny, it can't stay in that gear without a proper fluid level.who would have thought ....
Nice. I never needed AC in my house because it WAS always so cool. No longer, AC is going in a soon as my solar is running.It's sooo nice to be sitting here in an nice cool house drinking an ice cold beer. Last night without power about wore me out.
Glad you got some normalcy back. And a cold beer sounds kinda nice. I'll join you with a nice bourbon on the rocks...It's sooo nice to be sitting here in an nice cool house drinking an ice cold beer. Last night without power about wore me out.
do you still have the white GMC?Nice. I never needed AC in my house because it WAS always so cool. No longer, AC is going in a soon as my solar is running.
SWEEEEET!Wow guys and gals it actually brought tears to me. The second annual the lift is up day is at my house the week before Carlise from now on unless some one else wants to do it! Thanks like you would not believe. I know who did it if they want to admit it go for it. Thanks a lot my Kleenex bill is up this month!View attachment 1714953838 View attachment 1714953839
Yes just got it. Swapped the stock shocks for Bilsteins. 5100 seriesdo you still have the white GMC?
cool - literally it's amazing how it wears on ya isn't it!?It's sooo nice to be sitting here in an nice cool house drinking an ice cold beer. Last night without power about wore me out.
that's a 3500 right?Yes just got it. Swapped the stock shocks for Bilsteins. 5100 series
