nm9stheham
Hmmm... I am not following the argument for flat top pistons here for the Edelbrock Performer heads. The 60179 head is not that far from the X/J head; the 'open' raised area is .060" deep on the 60179 as opposed to the .090" depth typical in the X/J heads. With a standard Felpro head gaskets, the total depth is almost identical. So I am not quite seeing that you can't use the 60179's....What am I missing ???
BTW if the 'domed' piston in a BPC4080 short block assy is a KB356, then the raised dome sticks about .075" out of an undecked LA block. With a 60179 and a standard Felpro head gasket, then you end up with around .045" clearance, and you'll have quench. But if the decks are cleaned up, it will be less. Perhaps the open chamber warning is to allow for some serious decking in the machining? (But heck, even X/J heads can have problems with too much decking.)
And the KB416's have no dome on the pistons. TNT, what heads are you looking at using? Just curious...
