Carson13
Do I need to change to a different u joint when going from my 7.25 to a 741 case 8.75? If so, which u joint do I need to get?
Thanks in advance!
Thanks in advance!
Measure the outside to outside width of the u-joint on your drive shaft. 7260 joint measures 2 1/8". 7290 measures 2 5/8". If the inside measurement where your joint bolts up to the yoke is the same, your good to go. If you wind up with one of each measurement, you can use a conversion u-joint like a Neapco 11-726090.
