Belgiquebasterd
Hello, currently doing a T56 swap onto a Gen III hemi motor. Setup is not going into a A body but into a ram truck. I came here since it seems like a lot of knowledgable people visit this forum, and since it is a popular swap sharing my problems/findings might be good to know for other people doing the swap as wel as helping me with my swap?
This is the setup I have:
5.7 hemi
T56 out of a 2005 dodge ram viper SRT10 truck
Quicktime 8081 bellhousing (stock replacement for a 2009 challenger)
ACT twindisc clutch (stock replacement for a 2009 challenger)
2009 challenger slave cylinder
I have a spare damaged hemi block which I use for mock up of this project, when assembling all the parts I ran into a problem. The input shaft bottoms out on the clutch disc hub before the front bearing seats in it's bearing cup, as you can see on this picture, I believe the reason for this problem is the fact that I'm using a challenger bellhousing and clutch which is designed for the T56 magnum/tr6060 and not for the older T56.
I have assembled with and without the front plate and the distance from bellhousing to the end of the input shaft (syncro cone) is the same, so this should eliminate a problem with the front plate, when I assemble without front plate I can see that the input shaft splines 'bottom' out in the clutch hub, hard to take a picture, this was the best I could manage.
I have done some measurements and the input shaft needs to go an additional 3mm forward before it seats in it's bearing cup in the front plate. The locating dowels on the T56 front plate to the bellhousing are 10mm long, as a solution I could install an aluminium spacer plate in between the transmission and the bellhousing.
Now my question is, am I overseeing something, or would the spacer plate be a good solution?
Two issues that will arise that I can think off, possible many more will arise, that's why I'm here to get you guys opinions O
The clutch slave will need to be measured and shimmed out to compensate for the spacer
The pilot bearing will need to move forward, the stock pilot bearing is a smaller bearing pressed into a spacer sleeve, I was thinking of removing the smaller bearing, and have a thicker spacer sleeve machined to position the pilot bearing correctly again. Anyone see any issues?
So again my question, am I missing something or can I simply solve this issue by making a spacer to go inbetween the trans and the bellhousing?
And since everyone loves pics, some more of all the parts :cheers:
ACT flywheel that comes with the twinsdisc clutch kit
Thanks, Christof.
5.7 hemi
![DSC_0058_zps65a3e386.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_0058_zps65a3e386.jpg)
![DSC_0053_zpsf8f2461b.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_0053_zpsf8f2461b.jpg)
![DSC_0055_zps8ecb2869.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_0055_zps8ecb2869.jpg)
![DSC_0057_zps5d8052ff.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_0057_zps5d8052ff.jpg)
![DSC_00011_zps13577e0b.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_00011_zps13577e0b.jpg)
![DSC_00031_zpse77ec8a7.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_00031_zpse77ec8a7.jpg)
![DSC_00041_zpsa26c1ff5.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_00041_zpsa26c1ff5.jpg)
![DSC_0006_zpsbf4b8406.jpg](http://i292.photobucket.com/albums/mm11/Belgiquebasterd/DSC_0006_zpsbf4b8406.jpg)
Thanks, Christof.
