LocuMob
Fluid Technician
Just stumbled upon this, amazing work you and Larry have done! That's one of he coolest 318's I've ever seen.
Thanks,Just stumbled upon this, amazing work you and Larry have done! That's one of he coolest 318's I've ever seen.
Just with junk piled on it. This is what I'm going for, except with Weld Pro Stars:Hey nice color on your Dart by the way. Any full pictures?
Very Nice! Got an early 70's vibe going on there. I took the Cragers off of mine about 5 years ago. Had them on my car from 1985 to 2012. I changed to these Summit wheels when I converted to BBP. Wanted American Racing torque thrust wheels but these were $100 cheaper.Just with junk piled on it. This is what I'm going for, except with Weld Pro Stars:
Absolutely, happy to help in any way I canI am going to pick your and Larry's brain, later this summer, I just bought a set of turbo headers off ebay for a small block.
Thinking about building a twin turbo small block for that old cuda I bought.
So do you have a video of the truck running Now? Has it been to the dyno yet? Wondering what kind of power this will makeT for 2 update.
Well Larry and I have been busy Ironing out the fault codes with his Fitech. We had to shield his pickup wire and reroute other Fitech and MSD wiring but now it runs just fine. I will post pictures and idling video soon. We just installed the hood and grill yesterday. I the meantime you can check out my RPM noise solved thread with the video of my car idling wit timing control. I promise more pics and videos soon. Here's the link to the video of my Dart.
Fitech EFI Rpm Noise Solved
We have a video of it running but no Dyno tests. Actually we are now building a big block stroker for this. It will be Fitech injected and the same twin turbos but it will either have a tunnel ram intake manifold or ......a CROSS RAM! He already has both. The thing about the cross ram is that the wiring between the throttle bodies will have to be extended. I will see if I can find the video of the 318 startup. Not sure of the horsepower but I will tell you that at 5 lb of boost, it will break the tires lose no problem. We are keeping the Boost down because this is a stock bottom endSo do you have a video of the truck running Now? Has it been to the dyno yet? Wondering what kind of power this will make
Thinking of pulling the 440 out of my dart and doing a 360 twin turbo set up
Would like to run it something like this. Single efi though. I think this pic was on this site actually that I found.We have a video of it running but no Dyno tests. Actually we are now building a big block stroker for this. It will be Fitech injected and the same twin turbos but it will either have a tunnel ram intake manifold or ......a CROSS RAM! He already has both. The thing about the cross ram is that the wiring between the throttle bodies will have to be extended. I will see if I can find the video of the 318 startup. Not sure of the horsepower but I will tell you that at 5 lb of boost, it will break the tires lose no problem. We are keeping the Boost down because this is a stock bottom end
Shipping looks high on that kit.Yes I am just curious how much it put out for hp. I'm Thinking about using the T3 turbos from an eBay kit. It looks like everything is there mostly, will probably need to adjust piping and stuff but other than that it even comes with the battery relocation kit. Seems like a nice little kit. Wondering if anyone has used this kit before? View attachment 1715247106
I'm in CanadaShipping looks high on that kit.
Would like to run it something like this. Single efi though. I think this pic was on this site actually that I found. View attachment 1715247108
Cool thanks for the infoThat was from Maddart when he built that car which I bought from him, he used hedmen block headers and built the pipe to the turbo flange. If you go to page 9 I believe on this section and look for the build thread you can see how he did it, my motor is being built srill so I can't really take pictures to show you how he did it. **Twin Turbo 67 Dart Project**
But there are a lot of threads here for single turbo builds just go through them.
