Terminal source
1964Barracuda
Northeast Ohio
Rebuilding the dash wiring harnesses on my ’64 Barracuda.
Am looking for a part number, description, and source for the female terminals in the printed circuit board female connector (P/N 2258651). The actual female terminals are 5/8” long and fit over 3/32” diameter pins.
Also looking for a source for SXL wire in small quantities.
Photo attached. Thanks in advance, Ken
Those look OK. I don't recall an answer for replacements. Clean 'em up with some De-oxit.
What holds these 'bullet' terminals in the multi-connector?
I don't see a barb.
Nothing holding these round terminals in panel connector. Wire goes through the slot and pulled. Terminal bottoms, its diameter captures. If people could or would sort and straighten/align the wire, the black connector could be backed away leaving terminals on the posts. If several wires should come out through the slots, you have to know which/where they go back again.
Wirebarn.com sells GXL and TXL in a few colors and by the foot.
IIRC Waytekwire sells SXL on spools.
There was some other place on-line I found that had smaller spools but I can't recall right now.
I tend to use Marine grade wire when I can go and buy it in person. Insulation thickness is similar to GPT but rated for fuel/oil and higher temperature.
Rhode Island Wire has a lot of OEM insulation colors etc.
