jrlegacy23
68 Barracuda
I measured about 6.5" on the drivers side. I did not measure the passengers side. That is where I want to keep it even with the shorter tires on.
I had measured 12 3/4" from mounting point to mounting point. I am trying to decide, monotube or twin tube. If I get twin tubes, I am ordering a set of QA1's with 450 Lb springs.
If I go monotubes (which I am leaning towards), I am going ridetech with the 450 lbs springs:
http://www.summitracing.com/parts/art-24049901/overview/
HemiDenny
mono vs twin??? are you talking dampening?
looks good.....I expect a full report on the improvements you would like to see.
I added a bump stop 101 thread under suspensions....it's dead on!!
Hey JR, those rims look sweet!!!
The A/C inlet/outlet is right behind the intake manifold. If you 90* bends as it exits the firewall there should be no issues. I am thinking I may be going with the vintage air mark IV under dash mounted air conditioning as I like my A/C in the summer and want it to run very efficient and cold.
What about using a trunk mount ac unit ?
how far out from the frame is your hub? the measurement I shoot for is appox 12-1/8"
