mrhp Well-Known Member Joined Jun 24, 2005 Messages 150 Reaction score 92 Location SoCal 91942 Jan 5, 2018 #1 Do I need to use sealant with the Fel-Pro 35063 blue t-stat gasket? Thanks
rumblefish360 I have escaped the EVIL Empire State! FABO Gold Member Joined Jun 21, 2005 Messages 49,595 Reaction score 23,460 Location Florida Jan 5, 2018 #2 I use it. Skim coat. Just enough to coat it & to hold it.
Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,805 Reaction score 34,730 Location The Wolverine State Jan 5, 2018 #3 mrhp said: Do I need to use sealant Click to expand... I do as well. I also use some non hardening sealant on the bolt threads.
5.7 hemi FABO Gold Member FABO Gold Member Joined Apr 18, 2009 Messages 4,310 Reaction score 4,901 Jan 5, 2018 #4 I use an “o” ring thermostat housing, problem solved.
CL3406 Well-Known Member Joined Sep 24, 2015 Messages 412 Reaction score 79 Location BC Jan 6, 2018 #5 You can use sealant on the "blue stripe" Felpro gaskets. Do not use sealant if it is a Felpro "perma dry plus" gaskets. You are safe, the 35063 is just the "blue stripe" design. Check out www.felpro.com
roccodart440 Well-Known Member Joined Apr 19, 2010 Messages 6,810 Reaction score 3,594 Jan 8, 2018 #6 5.7 hemi said: I use an “o” ring thermostat housing, problem solved. Click to expand... Same here. Can't beat them!
