340Dust-her
What's your highest compression ratio without any use of methonal or any cooler. With a somwhat aggressive cam and 10:1, think it'll be fine on 93 octane?
just wondering if you have aluminum heads on either one???416 11.9 to 1 compression running on 93 pump gas...........
360 10.7 to 1 compression running on 93 pump gas...
Im running 11.7-1 with my 408 on pump gas.
You need to be much more specific. Regardless of piston, stroke, chamber, material, timing, pump octane, etc... The guide I follow is:
Iron open chamber - no higher than 180psi and dynamic ratio no higher than 8.3:1
Iron closed chamber - no higher than 190psi and dynamic more than 8.5:1
Aluminum open - no higher than 190psi and dynamic more than 8.5:1
Aluminum closed chamber - no higher than 205psi or higher than 8.75:1
Those basics havent failed me yet. they allow pump octane of 90 or so.
