W2 flow #s and Custom roller grind. What do you think?
Discussion in 'Mopar Racers Forum' started by mbaird, Nov 14, 2017.
  1. mbaird
    mbaird mbaird
    2,585
    466
    Dec 10, 2005
    boise, Id
    Local Time:
    8:47 PM
    I just got my W2s and Custom solid roller back from Ryan .
    This is for a 408 hooked to a 833 in a 69 Swinger. I am going for a street strip sleeper.. I plan using TTI W2 Race headers and a single plane intake (undetermined) .
    I was surprised at the amount of lift !
    Whats your thoughts?
    • Like Like x 2
    • mbaird
      mbaird mbaird
      2,585
      466
      Dec 10, 2005
      boise, Id
      Local Time:
      8:47 PM
      Compression is 9.7 and chambers are polished and CCd closed chambers.
    • yellow rose
      yellow rose Doctor of Thinkology.
      10,041
      6294
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      7:47 PM
      Pretty spanky for a 2.02 valve. Never heard of the cam grinder but I like the looks of it.
      • Agree Agree x 1
      • mbaird
        mbaird mbaird
        2,585
        466
        Dec 10, 2005
        boise, Id
        Local Time:
        8:47 PM
        Yes... 2.02 and 1.60...
        What other info didI forget?
      • justinp61
        justinp61 Well-Known Member
        932
        249
        May 15, 2009
        Local Time:
        9:47 PM
        It should be a fun ride, with that cam I'm not sure it's going to be much of a sleeper. lol
      • rumblefish360
        rumblefish360 so close yet so far away
        30,102
        2847
        Jun 21, 2005
        New York, on a Island
        View My Photos
        Local Time:
        10:47 PM
        Ooooooo, I like the spec’d cam numbers. I think that’ll be really nice for the description you gave.
        This is the kind of stuff I often state about cams. Get it the duration for what your looking to do with as much lift as you can get it in.
        This is in the rpm range of the street strip aspect and lots-O-lift to take advantage of the heads flow capabilities. By the time you figure in lash and valve train geometry loss, the lift should still crest .600, no problem IMO.
        Get the package set up to perform in the arena your looking for!
        Granted! Not the easiest thing to know from scratch.
        I like what Ryan did.
        • Agree Agree x 1
        • mbaird
          mbaird mbaird
          2,585
          466
          Dec 10, 2005
          boise, Id
          Local Time:
          8:47 PM
          I have Crower Xtreme duty offset cup roller lifters which I hope will help with geometry.
          I am really excited to see what the powerband and personality of this motor turns out to be. I will definately have to dyno this one.
          • Like Like x 1
          • 360duster
            360duster Well-Known Member
            931
            96
            Nov 23, 2008
            Bavaria / Germany
            Local Time:
            4:47 AM
            i like it....should run high tens if it hooks.
            Michael
            • Like Like x 1
            • mbaird
              mbaird mbaird
              2,585
              466
              Dec 10, 2005
              boise, Id
              Local Time:
              8:47 PM
              Any guesses as to what the powerband will look like? RPM limit ? Idle?
              I really dont know cam tech well enough to totally visualize the performance aspects of the final result.
            • 360duster
              931
              96
              Nov 23, 2008
              Bavaria / Germany
              Local Time:
              4:47 AM
              i guess peak torque slightly above 5000 rpm....peak power between 6500 and 6800 rpm. But to be honest i have no clue about the W2 capabilities ;-) What i know is it will be real strong.
            • mbaird
              mbaird mbaird
              2,585
              466
              Dec 10, 2005
              boise, Id
              Local Time:
              8:47 PM
              I initially planned on using a W2 Dual Plane because I really wanted a stockish appearance under hood. Now I have decided to go single plane.
              Victor maybe?
              Anyone have a ported single plane W2 intake?
            • rumblefish360
              30,102
              2847
              Jun 21, 2005
              View My Photos
              Local Time:
              10:47 PM
              I would look to ether the MP unit or the W2, Holley Strip Dominator. The Victor likes more rpm as I have been reading.
              • Agree Agree x 1
              • yellow rose
                10,041
                6294
                Jun 19, 2015
                Local Time:
                7:47 PM
                Or put a tunnel ram on that beeeeeeeeeeeeeeeoooooootch and let it rip.
                • Agree Agree x 2
                • Thanks! Thanks! x 1
                • mbaird
                  mbaird mbaird
                  2,585
                  466
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  8:47 PM
                  Nobody would notice that... Lol
                  Im not sure where this cam will rev out.
                  Its an interesting combo of big and little.
                  I was really expecting around .570 lift...
                  Dying to here (and feel) this run !
                  1st I need to find a competant shop to do the short block.... Urgh..
                • Duane
                  Duane Well-Known Member
                  322
                  62
                  Sep 29, 2009
                  Ontario Canada
                  View My Photos
                  Local Time:
                  9:47 PM
                  Here are the numbers Ryan got on my W2s with a 2.08 intake valve
                  And the custom Comp cam I am going to run. Strip car only though.
                  Regarding your combo I would say don,t miss a shift lol.
                • mbaird
                  mbaird mbaird
                  2,585
                  466
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  8:47 PM
                  That was a stage 2 port I assume.
                • Duane
                  322
                  62
                  Sep 29, 2009
                  Ontario Canada
                  View My Photos
                  Local Time:
                  9:47 PM
                  Yes it was. Interesting comparing the numbers. Yours almost max out
                  At .600 lift. Mine stall at that lift and increase again at .650.
                  These heads like lots of lift. I ran my heads before on a 344 unprotected and these heads really rpm fast.
                • rumblefish360
                  30,102
                  2847
                  Jun 21, 2005
                  View My Photos
                  Local Time:
                  10:47 PM
                  Interesting, very.....
                • mbaird
                  mbaird mbaird
                  2,585
                  466
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  8:47 PM
                  They do like RPM.. I ran a 360 with self ported W2s and that motor revved quick. Had to set shift light around 7k to keep from hitting 8k.
                  • Abodybomber
                    Abodybomber Breaking street machines , since 1983.....:)
                    29,532
                    8017
                    May 21, 2011
                    Arroyo grande ca
                    Local Time:
                    7:47 PM
                    This.. It 's not a Yugo... Grab all the torque ,you can get. It's no sleeper.
                  • Abodybomber
                    29,532
                    8017
                    May 21, 2011
                    Arroyo grande ca
                    Local Time:
                    7:47 PM
                    Cam grind is , nice.. It's strong enough, to run 6500 plus, out the back door...
                  • mbaird
                    mbaird mbaird
                    2,585
                    466
                    Dec 10, 2005
                    boise, Id
                    Local Time:
                    8:47 PM
                    Yeah... No one that knows cars will think its a 15 sec. car but I like a stock look and it will suprise many when it clicks off a 10.8 et.
                  • 1Fast340
                    1Fast340 Well-Known Member
                    570
                    46
                    Dec 30, 2011
                    Sweden
                    Local Time:
                    4:47 AM
                    That will kick some XXX :D
                  • mbaird
                    mbaird mbaird
                    2,585
                    466
                    Dec 10, 2005
                    boise, Id
                    Local Time:
                    8:47 PM
                    Looks like the Holley or Victor are good choices for intakes.... Any feedback on intakes?
                  • RustyRatRod
                    RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
                    44,179
                    7547
                    Jun 7, 2010
                    Georgia
                    View My Photos
                    Local Time:
                    10:47 PM
                    246 and 250 @ .050 on a 108 ain't no sleeper.
                    • Agree Agree x 1
