RogerK
I performed a full rebuild about three years ago with no issues. The car ran great getting 18 MPG. Now it leaks at the top of the carb between the center section and top of the carb.
I just replaced the 2 gaskets that seal the center section to the top and bottom and it still leaks at the top of the center section. I'm guessing the center section is now warped causing a lack of seal.
My questions are...
1) Can the center section be repaired, ie. flat sanded to remove the warping?
2) Are the center sections from other TQs all the same?
Thanks.
My questions are...
Thanks.
