greenswinger
Hi all!. Was curious about what ya'll were running for a transmissiion cooler. I went to the local pick and pull and got a cooler out of an '06 Dodge truck (1/2 ton) and one from a Durango. The Durango cooler is about twice as wide as the truck unit. These are the ones that bolt to the trucks radiator on the left and slips into the right side of the rad. Same width. I took some aluminum strap and made one unit out of it looping the outlet from one to the inlet of the other. I have a 26 inch Champion rad in the Swinger and used all thread unions on the rad bolts to stand off from the rad. This worked out perfectly. Looks factory almost like a AC condensor. Haven't tried it out yet since Im still wrapping the motor swap up. I would assume this is a bit overkill for a 3k stall converter but Im not running the tranny through the rad. Ill load a pic later....Heck Im thinking if they run 1/2 and 3/4 ton trucks with these coolers Im gold with this set up. Opinions?
