FlDart360
Ok I finally took the advice of those on this form and added a PCV valve back to my engine. The PO just had a breather on each valve cover. The carb is a Holley 670/4150 the motor is a very mildly cam 360 that is ok with pump gas. When I connected everything up now my idle has jumped from 850 to 1000. Before I start turning screws and messing things up I thought should ask what caused this. My throttle stop screw is only about one full turn off the stop and my idle mix screws are both about 1 ¾ out.
I hope by the time I get off work today there might be some idea as to what’s going on here thanks. Don't mean to post and run but this is bugging me.
