RandyB
I’m going to be getting the Edelbrock 1404 carburetor and want to make sure I purchase the right connections for the fuel line. Unlike the Holley 2300 Which I had a lot of trouble getting one to fit.
Hi Randy,I’m going to be getting the Edelbrock 1404 carburetor and want to make sure I purchase the right connections for the fuel line. Unlike the Holley 2300 Which I had a lot of trouble getting one to fit.
Hi Randy,
Please check out my archive post “Easy fix for 5/16 fuel line to 3/8 banjo fitting on Edelbrock 1406”. Use the “search forum” tab to find it. Hope it helps you solve your solution.
Take Care,
Greg
Sorry Rob, but I never took any pictures. I’ll see if I can remember to take some today after I finish all the chores and yard work. How’s that breathing machine I sent you to dry your engine air passages working out? Regards to you and Miss Kitty.Greg, that sounds like a pretty cool fix, but I'm stupid. You got any pictures?
I didn’t know what size fuel line a 1404 took... I’m sure Fragola has Proper size fittings for the 1404 also...Sorry Rob, but I never took any pictures. I’ll see if I can remember to take some today after I finish all the chores and yard work. How’s that breathing machine I sent you to dry your engine air passages working out? Regards to you and Miss Kitty.
Greg
Greg
Good to hear and glad I could help...That would be cool. Thanks. Ha! would you believe I've actually used it for that and it works good. I have to put a small hole in "the other side" to allow the air an "out" but it does work! lol
It did. Man the humidity down here has been a pain. Although this year I admit hasn't been as bad.
I have a Carter super pump with the 1/4 NPT. I tried to use the Edelbrock/Russel flexible line. The hose end was huge! Then came the fine print... ugh! What a pain!I didn’t know what size fuel line a 1404 took... I’m sure Fragola has Proper size fittings for the 1404 also...
Rob,Sorry Rob, but I never took any pictures. I’ll see if I can remember to take some today after I finish all the chores and yard work. How’s that breathing machine I sent you to dry your engine air passages working out? Regards to you and Miss Kitty.
Greg
