Hard block is basically cement poured into the block. Half filled is considered good by most and the most you would fill the block with street use and most race useage.I've never even heard of it.
At 500 HP a fill won't hurt you. You need a bigger oil pan. Your cooling system must be well thought out. You need as much coolant flow as you can get.
I've filled blocks after the machine work was done but don't like doing it. I never found anything move but I'd rather fill before machining.
An excellent idea running a deep pan and extra oil in conjunction with an oil cooler.I am already nervous about cooling issues in south Texas. I have a 3 row aluminum radiator and a fan clutch. I plan on using a Kevko or a Milidon and possibly plumbing an oil cooler.
