Will a 15" wheel fit on my 63 Dart
Discussion in 'Tires and Wheels (Mopar Hubcaps Too)' started by Hideogumperjr, Apr 26, 2012.
  1. Hideogumperjr
    Hideogumperjr Well-Known Member
    225
    219
    Oct 21, 2011
    Bothell, Wa
    Local Time:
    11:48 AM
    Since I am having difficulties finding the 195 70r14 tire I thought that maybe I might research a 15" wheel.
    If I get a tire say 195 60r15 that is 24.21" in diameter will going to the bigger wheel present unknown issues that might arise?
    Also it looks like the back space is 3 1/2" or 4" stock can someone verify?
    Thanks for all the patience folks.
    John
  2. zhandfull
    zhandfull Well-Known Member
    2,995
    54
    Mar 8, 2006
    Rancho Cucamonga
    View My Photos
    Local Time:
    11:48 AM
    15" wheel will work fine with that tire. Problem will be finding a 15" wheel with small bolt pattern. They are available by vintage wheel and stockton wheel. However I don't think the factory made any 15" small bolt pattern wheels.
    I don't know the factory backspacing as it depends on the wheel and width but it was probably close to 3.5" +/- a quarter inch
    • Like Like x 1
    • dartkory
      dartkory Well-Known Member
      304
      1
      Nov 22, 2007
      Portland Oregon
      Local Time:
      1:48 PM
      I believe that the factory backspacing was 3.375" but I have a 66 dart and run a 15x7 on back and 14x7 up front with the 4.125 backspace and they fit great. I also use a P235/60R15 for back and a P215/60R14 for front with no rubbing problems. I am actually selling my rallys that are only about a year and a half old and look great because i just got cragars. let me know if you are interested. Hope I helped. -Kory
      • Like Like x 1
      • Hideogumperjr
        225
        219
        Oct 21, 2011
        Bothell, Wa
        Local Time:
        11:48 AM
        To be clear I do have the BBP, I recently converted to the 5x4.5 discs on the front and am currently replacing the stock SBP rear end with a BBP 7 1/4" with 10" drums from a 73 Dart.
        I currently have the BBP 14" rallye wheels but am trying to decide whether to use them or go to a 15" wheel and tire.
        Dang, it used to be so easy, but some 45+ years have just kinda slipped behind me and dang if I can remember where I put them all!
        I know I could trim the fender where it is rubbing with the 215/70/14s but just dont want to do that unless I am trapped.
        Thanks to all and I appreciate any more suggestions.
      • grimreaper
        grimreaper Cross Member
        3,249
        124
        Jul 8, 2005
        Gillette, WY
        View My Photos
        Local Time:
        12:48 PM
        Plug your tire size into the fields on this page. Very helpful. Backspace is different according to width for factory wheels. I've got 195/60R15s on the front of my 64 Barracuda with the 73 up disc brakes. The wheels are 15X6 with 3-1/2 backspace and they work nicely. You've got a fair amount of room to play with in back so if you keep the diameter near stock your speedometer will remain fairly accurate.
        http://www.rimsntires.com/specs.jsp
        • Like Like x 1
        • az426hemi
          az426hemi Well-Known Member
          453
          5
          Jan 4, 2006
          Mesa, AZ
          Local Time:
          12:48 PM
          I had a pair of 235/60 on 15x7 steel Mopar wheels on the rear of my 63 Dart.
          Mike
          • Like Like x 1
          • shadowdog
            shadowdog Well-Known Member
            70
            2
            Apr 6, 2009
            Roswell, New Mexico
            Local Time:
            12:48 PM
            Try looking up Summit under BF Goodrich you should find your tire size.
            SD
            • Like Like x 1
            • RustyRatRod
              RustyRatRod Limp Member Technical Editor
              41,260
              3862
              Jun 7, 2010
              Georgia
              View My Photos
              Local Time:
              2:48 PM
              Will they fit on the front?
              • Like Like x 1
              • az426hemi
                453
                5
                Jan 4, 2006
                Mesa, AZ
                Local Time:
                12:48 PM
                No, I had 195/75x14 on the front.
                Mike
                • Like Like x 1
                • khoffman
                  khoffman Member
                  14
                  1
                  Jan 24, 2012
                  Meriden CT
                  Local Time:
                  2:48 PM
                  I have 15x7 cop car wheels on the front and rear of my 65 dart with 205/50-15 on front and 235/60-15 on the rear with offset spring hangers. No rubbing in the front, could go one size taller in the front with out any problem. I had 255/60-15 on the rear, but they rub some.
