Hi, i'm installing a Miloden windage tray stud kit in my LA engine. On Caps #2 and #4. ARP main bolts on the other ones. When installing these 4 studs -should i use Loctite on the threads or not? Two people have told me yes, two others say no. Some say all the way down by hand until it bottoms out and leave it there, others say back out 3/4 turn. Which is what and what is best or is it not really that critical? Its not being raced.
Also, stock torque setting is 85ft lbs, which is also what Miloden say for their main stud nuts. ARP (bolts) is 95 ft lbs. So why does Larry Shepard say 100ft lbs in his book "How to HotRod Small Block Mopars" (page 102) showing a picture of factory main bolts (!)
thanks
thanks
