Jhenry70
So, I been working on my engine harness, the car is a 72 Duster but the harness is out of a 71 340 Duster, I didn't have any harnesses except the under dash when I got the car. I'm going through the harness and pulling out some really bad splices and brittle wires (bulkhead connector is good) I'm also working on the ammeter bypass as well as wiring in a five position ECM and four post ballast resistor...
Doing pretty good with chasing and splicing in new wires and connectors, but spent a bit of time scratching my head on the factory chassis manual wiring diagrams. In the first picture you can see where I circled the areas in question. The bulkhead connector position "L" shows a DArk Green/Red wire going to the horns... The position "T" on the other connector has a yellow wire going to the starter solenoid. My actual connector has a yellow wire at the "L" position and looks to go to the solenoid. (I didn't have the other connector with me at the shop to see what color was coming from the "T" position.
Now the interesting part... the factory Chassis Manual (same manual) for the dash wiring on the inside bulkhead connector position "L" is labeled with a yellow wire and traces to the start position on the steering column (pic 3) and a dark green/red wire traced to the horn relay (pic 2).
Am I seeing this wrong or are the diagrams totally wrong?
