Wow how far can you bore a 340 before you go to far
MILO
Waterford,Pa
Never bore more than it takes to get round, straight bores. That motor has a stroker crank to get that big displacement.
Here is your answer!
As far as a sonic check says the walls are thick and your machinist will know (or freaking better!) how far is to far.
I have had 340’s cylinders so thin the machinist didn’t want to touch the virgin block saying it was a paper weight as deliver d from the factory.
I also have a OEM 340 where my machinist said he would take it an.100 over, no sweat, no problem!
THE BOTTOM LINE IS SONIC CHECK BLOCK BEFORE YOU DO ANYTHING!
Now what that advertisement fails to say is that the block has been BORED & STROKED to its displacement!
That's probably a 4.070 or 4.080 bore. That's only .030" or .040" from stock, respectively.
