73 Duster hood scoop
dustaar
Southwest Va.
I'm thinking about putting a hood scoop on my 408 Duster so I can use a carb spacer. As you know the 73 has a hood that is raised in the middle. Does anyone know of a 6 pac or a hemi style scoop that will work on this hood?
Thanks in advance,
Dustaar
PS
Thanks to all of you who gave me the advice on using an MSD6-2 box with an Autogage tach without an adapter. It worked fine without one.
Anyone????
See my pic under show us you scoops, I have a 74 with six pac scoop http://www.aarqualityfiberglass.com/cart2/index.php?cPath=57
and 1" spacer under my Air Gap, air cleaner is a chromed Edlebrock with 3" element, if you look into the scoop you can see the filter, plenty of room, the only issue I have is trying to figure out what I am going to do if it rains on my way home or going to a show, that scoop will fill my cleaner with water, that would not be good...
The rain issue is why I pointed mine to the rear, It rains here without notice
Andrew
