headers for 73 slant 6
will the dutra's work with a clifford intake?
google doug dutra and you will find everything about the duals. they are basically 2 seperate manifolds that each exhaust 3 cylinders and let you retain your factory choke. as far as the clifford intake question, maybe someone else can chime in to answer that.
hooker 5602 will not fit 73 swiger with power brakes...........has anybody worked that out?
it doesn't have my car as well which is a 1973 scamp. I am not sure but I think they can fit, I have headers in my car now and I have a power brake system. I am not sure about the Brand of headers but they look like Hooker headers.
i really doubt the hookers will fit with PB because the rear tube comes up and over the starter...
also you need to get rid of the column linkage and go to a floor shifter with a cable for clearance......
