Looking for dipstick/tube and rear sway bar.
It will be a 360/a727 setup. So is the 316 dipstick/tube the same for both engines ? I hall do some research and I may take ya up on your offer.
Grassy
From what I have read, the 360 is longer due to the size of the oil pan.
Thanks
Ian.
I think it would make a difference whether it's for a truck (rear sump) or a car (center sump) oil pan, but I don't know for sure. I have a truck engine. If there's a difference then I'll need one for a car pan too.
...........do u have a car pan, 360 is on its own...........273-318-340 r the same....u should b able to use the tube over, but u need a shorter stick.......kim...........
