Eddy spark plug recomendations
hypermite
Washington state
I haven't bought spark plugs for my Duster 440) yet, Edelbrock calls for small block plugs. What brand & part # (for those who have the Edelbrock heads) are you using ???? I've got the 84cc heads & 10.3 to 1 compression, if that makes any difference.
you are suppose to use 14MM x 3/4" reach gasketed spark plugs, they recommend Champion RC-12YC. I use these plugs and do not have any problems with the heat range.
Use some with anti seize slobbed all over them.
Thanks guys, That's the answer I've been waiting for. I've had bunches of FWD Mopars with alum. heads, so I know to use anti-seize, but I DO appreciate you guys watching out for my backside too !
Remember too remove them cold. If you remove them hot, it might not matter that you have anti seize on um. lol
