6dart9
- Joined
- Jan 8, 2008
- Messages
- 762
- Reaction score
- 14
if you have a small flat head screwdriver you can unplug the ignition switch and push the little metal piece that holds the wire in the plug. I would do that before clipping the wires if you are worried about it being "stock" if not dont worry red fish's idea sounds like a good one.
also you did put the gas tank sending unit ground strap on right?
