[SOLD] complete 70 340-4 speed partout!
340plot
the bushy bush
va
Rating - 95.8%
23   1   0
ok, before you all jump on me, this car is too far gone. i save alot of these cars, but even for me, it wold be too much.
this is one of a few i am going to try and pick up, so keep an eye out for other a body wrecks.
this one was hit high in the front, but bent passenger side frame rail. p.o was trying to fix it back in 77, and sandblasted both frame rails and cowl. well, after sitting outside, the wheather got to both frame rails, and ate them to nothing. the cowl has surface rust, but not bad.
every item i have for this car is numbers matching, including the 340 with x heads, hi-po manifolds. does not have origional carb. the 4 speed, with everything minus the clutch plate and shift rods. the shifter is there, along with flywheel, bellhousing, driveshaft, and all mounting hardware.
the rally dash is complete, but around the radio is cut for the face that goes with it. the harnees is all still there.
have the orginal k-hayes disc brake setup.
also have the original 8.75 with 741 3:23 sure grip. i am keeping the 323 gears, but will be putting 3 91 in their place.
quarters are gone, along with the trunk drop offs. upper trunk is fine, but needs spare area. floors look good. has original green bench interior, hump, pedals. seats need to be redone. all glass is good. rear frame rails are solid.
i have title, fendertag for this car.
i will leave open the thought of someone wanting to buy it as a total project, as it is a hard one to find.
but, all parts for sale....... all price up for negotiation!
the pic with manifolds is another set i got, and i know the passenger side one is not the 68-70 one!
all parts located 30 minutes outside martinsville international speedway in va
i have no clue what the valve covers are worth. make fair offer.
to all above. pms have been sent
Pmed on instrument cluster.
price on the heads, please.
also, on the set of hi-po manifolds
heads will not be sold seperatly.
manifolds are sold. i have left a 70 driver side hi-po with a 71 hi-po. not a matching set.
rallye guages and harness with all switches out of automatic car now sold. still have complete dash setup out of 4 speed car, with reverse light and all
Hey Plot I'm interested in the miss-matched manifolds and the headrests if they are any good. are they black or dk green.
Howard
nah, just am. but i have decided to keep this dash together, as i may be picking up another mopar shortly. so, dash out of 4 speed is no longer for sale.
can u send me a pic or put a pic up of the last 4 numbers from the trans and the motor so i can see they match and how much for the 2
not to be ignorant, but i see no purpose of posting the vin on the 340 or trans. i garuntee that they match, and come out of green car. i do not see no relevance of the two matching. they do.
as for price, i am nbot willing to sell the engine/trans and all other parts like driveshaft, shifter, flywheel, hump, pedals, and all other brackets for less than 2,500.00
it will cost me that just to do a fresh build on a 340 shortblock i have.
pics of valve covers, right at ya!
i am not asking to see total vin just the last 3 numbers like on each i have traveled along ways before and they said my bad i thought they where the same before i travel i just want to make sure thats all not looking for total vin?
no problem. here is the pics!
about the price, i am firm on the engine and trans, as i just pulled the oil pan off, and it looks fresh inside. all i am going to do if i keep it is reseal it with new gaskets, and valve seals
how much for rally dash,dash pad? how much for interior parts,like door panels,back side panels upper,lower.there is a metal piece above back lower panel. wireing under dash?thanks .cudaman bob
