WTB A230 3 speed manual transmission
kujo
NC
I'm looking for an A230 3 speed manual transmission from a 340/400 car. Doesn't matter if the trans has the long tail or short tail. The gear ratios differ between the /6-318 manual transmissions and the 340/400 manual transmissions. If you've got one let me know and maybe we can work out a deal. Thanks.
For slant sixes and 318
1st 3.08
2nd 1.7
3rd 1.0
R 2.9
for 340 and 400s
1st 2.55
2nd 1.49
3rd 1
R 3.34
I have a three speed, I need to check the ratios to make sure they are correct. Are there any numbers on the trans to indacate internal ratios?
69 340 dart
69 340 dart
I don't know if there's a way to check with the stamped numbers. One way to check is to put the tranny in first gear mark the input shaft and output shaft at the 12 o'clock position count how many times you turn the input shaft to make the output shaft complete one full revolution. If the trans has the 3.08 first gear it will be over three if the trans has the 2.55 first gear it will be just over 2 1/2.
