True A-Body 8-3/4 Rear Differential with Axles - Bolt-In
dragduster
Active Member
Battle Creek, MI
Rating - 0%
0   0   0
I have a true A-body, 8-3/4 rear differential housing. It is currently set up for drag racing or a little street use, but ready to bolt in. It has a spool, 30 spline after market axles, 4.10 Richmond gear set, solid pinion spacer, 1290 yolk, and long wheel studs. I pulled this from my Plymouth Duster after only 5 passes on the gear set to switch to the Dana 60 for this season. The leaf spring perches where moved inboard for leaf spring relocation kit (Can measure if needed). It is a 489 housing. Let me know if there are any questions or if you want some pictures. I should be able to meet part way, but would prefer not to ship because it is still filled with Royal Purple. I also have a used 4.56 gear set for added versatility that can be part of the negotiating. Otherwise, the starting price is $1000 OBO. I can accept Paypal, but cash on delivery is preferred.
Need to sell this to fix my big block, so the price is negotiable.
I forgot to mention that the bolt pattern is a standard Chrysler 4-1/2" for the axles. The center-to-center for the spring perch distance is 36" due to the narrowing for the inboard leaf spring kit. I need to get this out of my garage, so I am willing to part with this for just a mere $900.
Just bumping the add up to see if anyone is interested. I am willing to separate the pig and housing with axles. I was thinking about $500 for the housing and axles and about $400 for the pig all set up and ready to go with 4.10 gears, spool, and solid pinion spacer.
Also another bump with an update. I sold the pig, but still have the housing and axles. I will part with the axles for about $150 and the housing/axle combination for about $400. Let me know if anyone is interested.
p.m. sent. are they still for sale?
The axles are sale pending. I will let everyone know if they are back on the market. I can't believe the interest all of a sudden. I guess with spring around the corner, I am not the only one getting the itch.
