1973 slant 6 motor and other parts **Milwaukee, WI**
Matysik
Milwaukee, WI
Rating - 0%
0   0   0
I have some things for sale here since there is no interest in my whole car for sale I am going to keep the shell and sell everything else off to swap what I want into it this winter.
All new parts have 200 miles on them
Stock slant 6 motor with ~90k miles on it- 100$
-valves were just adjusted
-exhaust manifold is cracked
-New water pump
-will be a complete motor with new oil pan gasket, valve cover gasket, new dizzy cap and rotor, new thermostat, new plugs, new wires, new pcv, new valve cover unless someone starts buying the individual parts off of it.
-New chrome valve cover (I think its a Spectre brand)- 45$+ shipping new from summit so make me a decent offer
-stock distributor in good working order. (holds timing right where you set it)- make an offer
-Autolite plugs with sealing washers removed and wires with 200 miles on them- 20$
-Freshly rebuilt carb I bought off of here that is a clean rebuild but it's a reman carb so its up to to decide if you want to run it for the long haul. Works for me but I do think it has something to do with my drive idle problem or maybe I really don't know what I'm doing with these things :finga:- make me an offer on it
-stock torque converter- 20$
-stock trans- 100$ OBO
-New upper and lower radiator hoses- 15$
-stock radiator- 20$
-New transmission lines from summit- 15$
-Also have a fully disassembled 318 motor with all parts and a 727 torqueflite transmission that will not meet my power goals for 200$
Stock slant 6 valve cover- 10$
EGR block-off- 5$
-Slant 6 manifold holders- 5$
-Slant alternator and power steering belts with 200 miles on them (both Napa top shelf belts)- 15$
-318 starter?- 15$
-318 water pump pulley- 7$
-318 stock torque converter- 25$
-New Spectre valve cover comes with new gasket too- 45$
-Slant 6 fan- 7$
-Slant 6 Napa water pump with 200 miles on it- 25$
-Slant 6 water pump pulley- 5$
-New spark plug wires with 200 miles on them- 15$
-Slant 6 air cleaner assembly sanded down and painted. Not show quality but looked damn good on a driver and also comes with a new air filter- 25$
-Slant 6 dizzy- 25$
-Slant 6 fuel pump- 5$
-Slant 6 alternator bracket- 5$
-Slant 6 coil- 5$
-Slant 6 starter plate- 3$
-Slant 6- 3$
-Slant 6 thermostat with 200 miles on it- 3$
-Slant 6- 3$
-Slant 6 alternator and chevy 305 alternator bracket. Alternator has a broken bolt in the stock location so I just used the other bolt hole with this bracket with no issues at all. 20$ for the setup
-Autolite plugs with 200 miles and sealing washers removed. Also with spark plug tubes and new tube seals- 10$
-Radiator hoses with 200 miles on the, napa brand- 15$
-Slant 6 converter cover- 5$
-Stock 318 2 barrel carter carb- make an offer
-Slant 6 reman'd carb with Daytona rebuild kit (only charging price of the daytona kit)- 40$
-Another slant 6 single barrel with a fresh rebuild- 45$
the starter appears to be for a chev since the mounting bolts go up through insted of in through
-New water pump
Hello, what do you have left? I' m interssted in water pump, air cleaner belts. kevin
Do you still have a rebuilt carb (1920?) left? If so, please PM me. If you're in MKE, you must be pretty near by. Thanks.
EDIT: Just read the first post... not if it's the one that was maybe giving you trouble I guess :)
