prime wheels 15" 4.5" bolt circle
VDART
Shulte Ks
I have a set of these aftermarket wheels
Prime 15x7 with approx 4 5/8 backspace.
These fit 4.5 bolt circle bbp mopar
have all the center caps-- metal is all good -- the black plastic emblems are wore -- missing 1 set screw
I verified with an axle 8.25 style not just measuring it. I will have the tires dismounted before shipping.
$300 obo including shipping to the lower 48 states
parts are in Wichita Ks 67209
thanks Lawrence
sorry -- no tires--- they would greatly increase shipping, thanks for the heads up-- interested?
Do you know whether or not they would fit a 74 duster for sure? I'm concerned about the backspacing.
I do not have a test mule-- to try on-- I only have a 8.25 rear to test fit-- I'll ask the forum for some help-- Lawrence
got a test mule-- mounted these on the front of a 75 duster--- will have pics of the rear mount Monday.
all I can say is they look good on the front 205/75/15 tires(I think)
rear of dart sport, for this offset to work on the rear a spacer would need to be added-- the rims push the tire in the wheel well .
I f a wider than normal rear -end swap was done this offset would be much closer --
same tires as the font pictures-- this is a 73 dart sport for the rear the fronts pictured were on a 75 duster.
. Lawrence
