Trunk Extension R&R
gerahead
Glutton for Punishment
Maple Grove, MN
I pretty much had myself convinced that I was just going to replace the portion of the extension that was eaten away. Today I got the AMD replacement that I ordered and it is just too nice to not use in its entirety.
So I am looking for advice from those of you who have done this before.....what's the best approach? The quarter panel is cut away so that won't be an impediment. I am thinking that the best approach might be to cut as much of the excess away as is reasonable to that I can get at the spot welds easily. Since I will be replacing one side completely anyway, it seems like drilling all the way through the spot welds is easiest. It'll get them out of the way and then I won't have to punch any holes for the plug welds on the new steel. Make sense? I am open to all suggestions. Thanks guys. L8r
Thats what I would do! Just be sure to use weld-through primer on all surfaces that you grind the EDP off of.
Use a jigsaw or a bodysaw and cut on the outside of the pinchweld where the trunk floor meets the extension then you can drill through all the spotwelds. I use a Uni-bit, some call it a step bit. Quick and easy!!
Thanks 'Dak. The unibit is exactly what I was planning to use. Looks like the new close-quarters drill will get some use! L8r
