How Do You Remove AM Radio and Heater Bezel?
Remove the radio knobs, and there will be a nut under each knob, a 5/8" I believe? Then take the heater knobs off. You may need to pull your glove box liner to reach behind the dash, but there will be 3/8" nuts holding the bezel to the dash.
WARNING have band aids on hand! everything behind that dash is SHARP! :o
There should be a set screw that needs to be loosened on the little chrome knobs for the heater controls.
Don't forget there may be a small metal brace on the right side near the bottom (passenger side) 3/8" or 7/16" nut on a stud off the radio, and a screw underneath the dash..
