I went and put this welder in layaway tonight.
http://www.tractorsupply.com/hobart-handler-reg-140-mig-welder-3812040
$479.99
$449.99
In stores only
Product Reviews
Overall Customer Rating:
42 out of 43(98%)reviewers would recommend this product to a friend.
Read all 43 reviews
Write a review
Follow this product
Product Description
SKU Number: 3812040
Manufacturers Number: 500500
Brand: Hobart
Process Type: MIG, Flux Core
Welding Amperage Range: 25-140 A
Input Voltage: 115 V
Weld Thickness: 24 ga. - 1/4 inch - Single Pass
Duty Cycle: 20% @ 90 A
Product Length: 19-1/2 in.
Product Weight: 57 lb.
Warranty: Limited Manufacturer's Warranty
Product Width: 10-5/8 in.
Product Height: 12-3/8 in.
View Demo
View Demo Video
View Brochure
Built with Hobart quality & durability, the Handler® 140 is Hobart's most popular wire feed welder - it is MIG ready, no additional kit required. The Handler® 140 is a wire welding package with industrial performance, operating on standard 115V household current. Extremely versatile and perfect for the welder that wants to work on auto body, household repairs, or even heavier farm projects that require extra power. Tapped voltage gives you the best possible power and arc available while welding. Includes: comfortable 10 ft. H100S2-10 MIG gun with liner, built-in gas valve, dual gauge regulator and gas hose, 10 ft. work cable with clamp, power cord with plug, extra .030 in. contact tips, sample spool of .030 in. flux-cored welding wire and 8 in. wire spool adapter.
$479.99
$449.99
In stores only
Product Reviews
Read all 43 reviews
Write a review
Follow this product
Product Description
SKU Number: 3812040
Brand: Hobart
- Description
- Reviews
View Demo
View Demo Video
View Brochure
- Welds 24 ga. up to 1/4 in. mild steel in a single pass
- Operates off 115V household current
- 4 voltage settings for precise set-up
- 30 to 140 output amperage
- Duty cycle - 20% at 90 amps
- Dual groove, quick change drive roll
- Self-resetting thermal overload system protection
- Built-in contactor eases use and is an excellent safety feature which makes wire electrically "cold" when not welding
- Manufacturers limited warranty
