273 exhaust manifold ID help needed
jdrew
New Member
Minneapolis
Hello everyone! Joined this site to learn a litte about the 273 V8, I happen to be dropping one in my 1950 Plymouth Suburban wagon.
With that, here is my question...
I picked up a 273 drivers side manifold, to clear the stock steering in the 50, the part number is 2465847.
I would really like to find a matching passenger side, but I need help identifying one with the correct part number. As anal as it sounds, I would like to find the correct manifold that technically matches the drivers side.
So, can someone here help me ID the manifold so I can start my search?
Thank you in advance for your help, this site sure has a lot of nice A-bodies and technical info.
Welcome to the site.
I have a listing on pdf. that i cant seem to transfer here....i will keep trying though.
It shows your left casting 2465847 as a 64-66 A body. The part number is listed as 2465848
It shows the right 64-68 A body as casting 2465769 and part number 2465766
Hope some others can confirm and again, welcome to FABO.
Here's the link.........
http://api.viglink.com/api/click?format=go&key=508e022f256315a50e8e5af8c001704f&loc=http%3A%2F%2Fwww.forabodiesonly.com%2Fmopar%2Fshowthread.php%3Ft%3D204139&v=1&libid=1358730768120&out=http%3A%2F%2Fapicdn.viglink.com%2Fapi%2Fclick%3Fformat%3Dgo%26key%3D508e022f256315a50e8e5af8c001704f%26loc%3Dhttp%253A%252F%252Fwww.forabodiesonly.com%252Fmopar%252Fshowthread.php%253Ft%253D204139%26out%3Dhttp%253A%252F%252Frandymacsmopar.zzl.org%252FPDF%252Fexh...pdf%26ref%3Dhttp%253A%252F%252Fwww.google.com%252Furl%253Fsa%253Dt%2526rct%253Dj%2526q%253D%2526esrc%253Ds%2526frm%253D1%2526source%253Dweb%2526cd%253D4%2526sqi%253D2%2526ved%253D0CEgQFjAD%2526url%253Dhttp%25253A%25252F%25252Fwww.forabodiesonly.com%25252Fmopar%25252Fshowthread.php%25253Ft%25253D204139%2526ei%253Db5X8UPvVAomk8gTSiYGIDw%2526usg%253DAFQjCNHlgXiUTQNA44_NPFBdBPmK62MM8w&ref=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3D%26esrc%3Ds%26frm%3D1%26source%3Dweb%26cd%3D4%26sqi%3D2%26ved%3D0CEgQFjAD%26url%3Dhttp%253A%252F%252Fwww.forabodiesonly.com%252Fmopar%252Fshowthread.php%253Ft%253D204139%26ei%3Db5X8UPvVAomk8gTSiYGIDw%26usg%3DAFQjCNHlgXiUTQNA44_NPFBdBPmK62MM8w&title=Exhaust%20Manifold%20Casting%20%23's%20-%20CORRECTED%20340%20%23's%20-%20Tech%20archive%20-%20Mopar%20Forum&txt=http%3A%2F%2Frandymacsmopar.zzl.org%2FPDF%2Fexh...pdf&jsonp=vglnk_jsonp_13587307616834
The 2465847 LH manifold is for 1964 to 1966 273 A bodies.
The casting number for the RH exhaust manifold is 2465769.
This manifold is for 1964 t0 1968 A and B body 273 and 318LA vehicles.
Herb
Can't help on casting number, but if you are using the original frame and steering from the '50, get yourself a mini starter or a starter off of a Dakota. When I had the 318 in my 51 Plymouth, I started out with a stock starter and the end just touched the steering box, and had to slide the tranny back to change starters, I switched to a Mopar performance mini starter and it gave me a lot more room.
Great tip, thank you! I am keeping the stock frame and steering...may swap a r&p in at some point, but not right now.
