RH- 67 dart back door
68 valiant dramatically different??
am going to venture dart does not have the bottom crease line seen here on the valiant.
nice clean door whats the bottom seams look like ,and looks good on the out side whats the inside looking like ,is there much rust and ,what are you looking for in price ,don't want the door interior panel or arm reat just pain door skin ,needed.the lines look like they are the same ,hard to tell ,if i knew how to return you with a pic of my door then we could figure out are they inter changeable doors.
thanks ..
dartpower...
PM Nite Moves. He bought my 67 4dr Dart. He may still have it. Or most of it, anyway. Good luck!
Hollander (42nd Ed, 1976 - Section 9A) shows:
67 Dart rear - #1925
68-76 Dart rear - #1996
67-73 Valiant rear - #2006
74-76 Valiant rear - #1996
interchange section at back of Section 9A states:
#1925 fits 68-76 Dart and 74-76 Valiant (both #1996)
so apparently the 67-73 valiant rear doors did have a "divisional" identity
rear door - guess the rear lower crease was moved to "align" with the dart for the 74 / 75 / 76
model years.
In summary, a 74 - 76 valiant RR door would work for you but not earlier years (67 - 73)
the 75 four door (valiant) i posted a few months back would have worked but it is already gone to the scrap heap in the sky.
dart and valiant rear doors are different the rear door of a dart has an up swept bodyline starting just before the rear door handle and a valiants body line continues flat all the way to the rear, see pick of the blue 67 dart look at the trim you can see the up shift of the body line. and the green 68 has a nice angled view that you can see it as well. the above pick of the white valiant door shows the straight body line of a valiant rear door hope this helps clear up any confusion.
