SB TTI's, Dougs- Question
mopowers
West Sacramento, CA
Before I mount my adjustable proportioning valve, I want to make sure it won't interfere with the TTI's or Dougs I plan to install in the future. I plan on mounting it about 6-8" down from the original prop. valve on my 68 Dart.
Will there be any interferance with either one of these headers? Can you guys with tti's or dougs post a pic of the underside of driver's side just so I can get an idea of how they're run???
Thanks!
If down means towards the rear, further back you go to a point the more room you get from your headers. 12" would likely be better than 6-8".
Hope this helps, best i could do without jacking car up !
