Den's Dart
Guys, I know this may seem like basic trouble shooting to you but help a newbie out here please (without tearing me down preferably!
Started the Dart up on the weekend for the first time since the winter and noticed it just didn't sound right (Didn't sound the greatest when I put it away in the fall to be honest!). So I took my infra red temp guage and took some readings at the manifold. Atleast one cylinder is definitely not firing (The readings on the left side back 2 cylinders were much colder but the back left was considerably colder than the rest).
I swapped in a new plug, no change.
I swapped a wire, no change
I did not swap the position on the distributor.
So, where would you guys head next? would you suspect the Cap/rotor or the ignition module? Any way to rule one out? I don't have a compression tester and to be honest I am dreading the thought that it is NOT ignition related!!
Also, just to be certain the plugs are wired correctly does anyone have the layout for a 1970 340. I assume the PO has them in right order but you just never know....
Thanks in advance,
Dennis
Thanks in advance,
Dennis
