NOS 340 dr side EXHAUST MANIFOLD
ph23vo
seattle
72-74 perfect NOS never used still has cosmoline on it DRIVER SIDE 200.00 SHIPPED USA..same flowrate as 68-71 as its the same internally..just added casting for later cars carb heat tin is all..
outlet is the std 2 1/4 same as all 340 manifolds 3614368 cast #
hopefully this might help too, these manifolds WILL fit early a's with a conversion steering coupler, which should be a must imho. GLWS!
OK
Explain the Dakota manifold for the passenger side, I have an original 340 part that needs repair, would the Dakota part be a cheaper alternative.
Sorry to hi-jack, Dave
OK
apparently (not speaking from experience here) the Dakota v-8 manifolds will bolt right up; they have 2 1/4 outlets, so the flow should be similar. Passenger side bolts up with no modification, it is the driver side that can work, but with some modifications. Thats why I would use the manifold above along with a Dakota passenger side.
