1970 Plymouth duster 340 H code automatic
Four wheels
Active Member
Oregon
Rating - 0%
0   0   0
Car has been off the road for more then 25 years. It's a B 7 blue, paint has patina , interior will need to be redone, the front and back seats are worn, it's an automotic on colum . Interior is blue, the motor is non matching 340 1969 block with X heads, everything else is stock from air cleaner to rallye wheels. It's a very solid driver, and cool car. Comes with build sheet. Perfect grill and all glass good with no issues, all lights work and gas tank as been cleaned. Carb should be rebuild.:prayer:
$7995
$7995
Welcome to FABO.....................
$7995
Thanks.
I PM'ed you and replied back to your ad.
THANK YOU,
Stew
welcome aboard, were in Oregon are you located?
does it have a fender tag also?
make the picture internet friendly/ select quote/ select the paper clip - brings up another window/ choose file/ select picture/ select upload. done.
We're do u get info on how to post pics...thx for help
Car is located in Salem Oregon. Looks to be all there. Needs cosmetics, but don't they all!
Damn. I would put the stock hood and deck lid back on, tune that baby up and drive it as is.
Im sick of restored cars.
Good luck with the sale.
im pretty sure 68 was complimenting the fact your car could be enjoyed as is for what it is & not another trailer queen ....was not an insult
Just had new carb put on...stock is being rebuild....has new exhaust ... So almost a driver, except the original disc brakes need to be either redone or like some say update to 73 plus
On removing the K/H original discs for the later '73 - up large bolt pattern, keep in mind that you can buy the original K/H parts for reasonable prices (rotors, calipers, pads, hoses, etc.). Check Rock Auto for availability.
By the time you do the '73 - '76 switch you will have a fair amount of money in that conversion, unless you already have the entire setup with all the pieces.
Also keep in mind if you do the conversion, you will spending money on wheels.
Finally, your car is not a /6 or 318 car --- it is a factory 340 car. Converting a non 340 car to LBP is a no brainer. The more you maintain the car towards the original configuration, the more that becomes a selling point.
And if all you are doing is flipping the car, then originality is probably the better selling point.
Just my .02c
Price of car is 6995.00. Will come with stock hood and trunk...will not come with hood scoop and wing. Thx for consideration ...peter
Thanks for the update.
Salem Oregon weather appears to be favorable for taking pictures outside, using a high resolution camera. A number of members asked for specific closeups so this is a gentle reminder to the seller that we would all like to see better quality closeups of the car, in order to determine whether the car meets peoples expectations.
Thanks and looking forward to those pixs!
