[SOLD] FOR SALE: 1972 Dodge Demon Dual Snorkle Hood Scoop Factory Mopar 72 Dart 340 Nice!!!
66340SEDAN
FABO Member #3649
Minnesota
For sale is a factory Mopar dual snorkel hood scoop from a 1972 Demon. All the mounting studs are good and appear to be factory ones. The paint is not the best and its flaking off in some areas so it will need a repaint. Has the original Mopar part number on the inside too. I was gonna use this on my 66 Valiant but would have had to midify the front of the scoop where the hood is raised, couldn't bring myself to modify a factory scoop, plus, I have plans to install a tunnel ram soon so the scoop is not needed lol. $265 shipped to your USA door. Sold as is, I am in central MN, thanks FABO :glasses7:
Here are some better pics. There is a crack at each corner and possible a minor one at the rear (see pics) doesn't look like much was done to repair it but it should be an easy fix, its made of fiberglass. There are some small chips on the base around the bottom but again, this is minor. One stud is missing and the hole looks stripped out, but the other studs Are all there. Looks like there was some putty type sealer added to the base of the studs to seal it to the hood? It comes off easy, one stud has a big clump of it, not sure why, maybe it is a repair? I didn't want to mess with it, I can't see any damage. Also, the repaint was a thin coat, I see no hidden damage other than what I pictured here, it doesn't have multiple layers of paint or gobs of bondo. A little body work on this and it will look like new again :glasses7:
Sorry for all the pics, just want to show it and be honest about its condition, thanks :D
Got shipping quote today for the 1st in line to Canada, if he passes I will go down the line to the next member, thanks :glasses7:
